All About: Roaming
Anything I need to do before I go abroad?
  • First things first: If you have never used your Three phone abroad, reach out to us here on the 3Community to check that roaming is enabled on your account.
  • Travelling within the EU: Most of our plans include an EU data allowance. If you are not sure how much your plan includes, you can check your roaming allowance through your My3 account. 
  • Travelling within the UK: Although the UK has left the EU, your EU roaming allowance applies.
  • Travelling outside the EU: Customers can roam in any country that Three has a roaming agreement in, and charges apply to ALL usage. Your data will make a connection straight away to the local network.
  • As your data will connect to a local network as soon as it's available, we recommend that you switch off your mobile data before you travel. This way, your phone will not connect to any international networks without your knowledge. We also recommend that Wi-Fi Assist or your phone equivalent is also turned off. If you need help turning these off, please select your phone in our Device Guide for step-by-step instructions.
  • Read about our international roaming rates by clicking here.  Want to help reduce the cost of roaming? Why not check out what roaming add-ons are compatible with your plan by reading our price guides here.
How can I get a roaming add-on?
Click here for more
To find a roaming add-on that is compatible with your plan, log into your My3 account by clicking here, and select ‘Explore Add Ons’.
To change your roaming message/alert settings or to reset your data roaming cap, you can find out more by clicking here.
What should I do when I arrive at my destination?
Click here for more
On arrival, your phone will automatically look for and connect to the local network. For your data to connect, make sure that mobile data roaming is switched on via your phone settings. For help doing this, please check out our Device Guides.
What is Wi-Fi Assist, and do I use it while roaming?
Click here for more
Wi-Fi Assist (or Smart Network Switch on some Android devices) is a device feature that automatically switches your device's internet connection from Wi-Fi to cellular data when the Wi-Fi signal is weak or unavailable. While roaming, it’s a good idea to switch this off to avoid data roaming charges. For steps on how to switch this off, click here and select your device.
How do I connect to a foreign network?
Click here for more
Can I roam using an eSIM?
Click here for more
Yes, roaming with an eSIM is no different than roaming with a standard SIM.
Can I use an international SIM while abroad?
Click here for more
Yes, you can use an international SIM while abroad, but you may need to unlock your phone first.
Click here to unlock your phone.
What is EU ‘Roam Like Home’?
Click here for more
The European Union has amended the rules regarding roaming rates. The overall aim of the roaming regulation is to allow users to use their mobile phone at home or within the EU where the same charging mechanism will apply. This regulation commenced in June 2017.
Where can I find a full list of roaming rates?
Click here for more
Click here to check out our roaming rates.
How can I check which services are available when I’m roaming?
Click here for more
Click here, select your destination and enter your mobile number. The services available to you while roaming, along with the costs, will then be displayed.
What do I need to do to roam within the EU?
Click here for more
Nothing, all new Three accounts are sold with roaming activated. If you would like to learn more tips and tricks about roaming, check out our blog All About: Roaming with Three by clicking here.
Does my plan include roaming?
Click here for more
All of Three’s current plans include EU Roaming. The units included vary depending on the plan, so please click here and select your plan for more information regarding your specific roaming allowance. Note that these units can also be used in the UK.
How do I check my roaming allowance?
Click here for more
To monitor your allowance, all you need to do is log into your My3 account online by clicking here or through the My3 App. You can also check your spend by texting ‘BALANCE’ to 50272.
What if I need to top up while I’m travelling?
Click here for more
Topping up while abroad is easy! Just log into your My3 account or App and click ‘Top Up Now’, or click here to Top Up without logging in.
How can I control my spending while abroad? (EU/Rest of the world)
Click here for more
There is a number of things that you can do to control your spend for information on these things, please check out our blog How to Avoid Large Roaming Charges
For information on our Data Roaming Caps and all about how they work, see below:
Click here and select your plans to learn more about your roaming add-ons.
Can I use my phone on a flight or at sea?
Click here for more
Service in flight or at sea is not guaranteed. When it is available, however, you are roaming on a satellite network and you will be exposed to high charges.
You can also check your rates before travelling by clicking here and selecting “Satellite (Maritime/In Flight)” for the country that you are visiting. It is important to note that if you are on a ship/flight within the EU region, this is not part of EU roaming regulation.
If you are travelling by air or sea, we recommend that you switch off your data before you leave to avoid unwanted charges, and connect to Wi-Fi if possible. Please note that such Wi-Fi may be chargeable, so please check with the provider before connecting.
Click here for more
Normal networks are land-based. Satellite networks are mostly used while out at sea or travelling by air. Satellite networks are not included as part of any roaming allowances, meaning that they are an additional charge, so please review the charges before connecting. Click here to find out about Satellite charges.
Click here for more
Can I use my Mobile Broadband when I am roaming?
Click here for more
No, Three Mobile Broadband devices are for use in the Republic of Ireland only.
We recommend that you carefully read our tips before travelling.
*Body of European Regulators for Electronic Communications
16 Comments
